Thank you GTVi, you were absolutely right, that was exactly the problem.![]()
Turned the needle back and its back to normal.
I checked calibration too (using the speed alert and my GPS) and its fine.
Couple of tips for anyone needing to remove the cluster;
First, do yourself a big favour and remove the steering column shroud first. I didnt and had a job to manouver the cluster surround out over it. Too tight.
Secondly, there is some kind of insulation covering the cables at the rear which is aged, sticky and crumbly. Dont touch it if u can cos it sticks to your fingers and then gets all over the clear cluster shield. Cleaning it was a pita.
